10-09-2024 01:18 PM
Where do we check network status or report an outage? I appear to be offline but I was definitely online and able to make calls about an hour ago. Just wondering if it's localized or a larger issue, but I'm not sure how to check.
Service
10-09-2024 01:27 PM
hi @Tagracat
the official outage is here
https://www.telus.com/en/on/outages
or you can ask PM to check if any outage in your area by submit a ticket using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
10-09-2024 01:20 PM
For service outage check these 2 sites:
https://istheservicedowncanada.com/status/telus/map
I guess only major will be reported there. As for YOU reporting outage try to find any Telus email and let them know. There is No way to report if PM has outage as there is no email nor phone number.
10-09-2024 01:19 PM
@Tagracat check
Outage map in your area:
and you can report it to support
