Issue with towers or Outage?
Aloe90_09
Hi since this morning my phone has been switching from no service to public mobile and I don't have any "bars".
Is there currently any issue like an outage?
I'm in Montreal, Quebec.
1 REPLY 1
hi @Aloe90_09
did you login My Account and check if your account is account?
And there are currently active outages affecting Easy Ontario and Ottawa.  if you live close to Ottawa, maybe it will affect you as well
https://www.telus.com/en/on/outages
you might also want to ask PM agent to check
submit a ticket with CS Agent using Chatbot here:
             Type the question "Ticket", Then click the following in order: "Account Management" , "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
