07-25-2021 03:04 PM - edited 01-06-2022 02:54 AM
Hello
I am currently in the US (roaming) and unfortunately Im having issues with my SIMcard
I plan to purchase a new SIMcard in Toronto and have my relative mail it to me here in the US..
Would publicmobile recoginze/accept if I change the SIMcard while in the US/Roaming connection?
thanks
07-25-2021 09:40 PM
@echo7 wrote:exactly!... that's what Im worried about!..
I will keep using my working sim.. when it fails.. thats the only time I will replace..
I will have my relative in TOR send the new sim by mail .. just in case
thanks
@echo7 make sure your relative get the SIM from local kiosk or Amazon if they have Prime membership. DO NOT order from PM online. It might take 3 to 4 weeks for delivery if you order from PM
07-25-2021 08:44 PM
@echo7 wrote:Hello
thanks
So, yes, you can do a sim swap while roaming, you just need to get the SIM card in your possession to be able to use the service.
As of for your error issue, check network operator settings.
Set device network operators as LTE/3G/2G (auto connect) mode.
07-25-2021 07:37 PM
I feel like this poster might be asking a different question. OP, I don't think it should matter when you change your SIM card!
07-25-2021 05:33 PM
thanks
07-25-2021 05:27 PM - edited 07-25-2021 05:32 PM
BTW....changing your sim card while in the US is kind if YMMV as the moderator said you could try swapping it out yourself in your account and if it didn't work to contact them to help. So I guess there will be a guinea pig come along eventually to confirm yes or no. I call it a maybe.....not that it applies in your situation. I would stick with the one you have......FYI Only!😃
Moderators are not busy today....maybe you want to contact them.
Edit: In theory though the mod said it should work....and to manually select your network.
Stay--Safe!
07-25-2021 05:18 PM
ok I did the "reset to default" on the APN settings...
I will observe if it happens again
thanks
07-25-2021 05:09 PM
@echo7 did you try manually connect to TMobile? some city is better with one network and not the other..
07-25-2021 05:09 PM
rebooting your phone
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
07-25-2021 05:09 PM
Changing the SIM card may not necessarily solve this problem. Just did a quick google search and other users have had similar issues with same message. Different work arounds. Seems like mostly users in the United States. If you return to Canada, the issue might just resolve by itself.
One example:
https://community.virginmedia.com/t5/Virgin-Mobile/Refreshing-sim-data/td-p/4721236
07-25-2021 05:06 PM
yes.. I did the APN thing, the LTE (instead of Global) and also manually connected to Tmobile but the "refreshing sim data" still appears..
07-25-2021 04:43 PM
You need to manually choose between at&t and t-mobile.
07-25-2021 04:41 PM
Thanks for the quick reply all!
I am having "refreshing simcard data" message.. though no connection issues but this message randomly appears...
I can see my connection switch between ATT and Tmobile
I am afraid that my simcard will fail on my way back to Toronto. I need to be connected to upload my arrivecanada details.
07-25-2021 04:00 PM
07-25-2021 03:31 PM - edited 07-25-2021 03:32 PM
Yes, you can change your sim card. What are you actually experiencing while roaming? Did you purchase the roaming add-on? Has it expired? Have you contacted mods to have them take a look at your account make sure everything looks as it should
07-25-2021 03:12 PM
visit Here for more information.
How To Change Your SIM Card
the SIM change functionality has been re-enabled in My Account, now with an additional security step: 2 factor authentication to further protect against SIM card fraud.In order to change the SIM card associated with your account, you must now verify your request through a one-time security code that will be sent via SMS or email.To change your SIM card, please follow the below steps:
Please note: after 5 failed attempts to verify your security code, your account will be locked, and you will need to have your account unlocked and your SIM card manually updated by an agent by submitting a ticket.
and sorry how you know is issue with your SIM card !! and now your old SIM card is working ?
07-25-2021 03:08 PM
Customers are able to change their own SIM card these days. It is a 2 factor authorization when you can choose either text or email authorization.
Are you sure that it is a SIM card issue? Sim card don't fail often. Maybe describe your issues and the community members may be able to help.
