12-14-2023
12:14 PM
12-15-2023
09:24 PM
Dunkman
12-14-2023 02:06 PM
Resolved, thank you
12-14-2023 01:33 PM
@DavidMary1 If you bought the incorrect add on first and will need to submit ticket with support to ask if they can reverse it for you
send a private message To CS_Agents
12-14-2023 12:16 PM
Update: I willnever use the roaming add-on. I can't wait for the US long distance so I am adding it now. I just need the roaming one removed. Thank you.
