09-27-2025 11:22 AM
My son broke his phone but his account shows as having used 1GB.
This is obviously incorrect. While it's well under the amount of purchased data it's concerning that it's being miscounted.
2 weeks ago - last edited 2 weeks ago
@hutchic you need PM to check and clarify .
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
2 weeks ago
2 weeks ago
2 weeks ago
2 weeks ago
@BKNS27 -- I'm aware but that shouldn't be reported as data used over the mobile network
@Camera4617 -- becuase there's literally no SIM in the phone it's impossible for it to use mobile network data
@hairbag1 -- that's where the usage number came from
09-27-2025 03:51 PM
09-27-2025 12:32 PM
How do you know it is incorrect? He did not use it at all? Or you think he used less than it shows?
09-27-2025 11:37 AM
He should log in to his account / Usage Breakdown to see accurate usage info.
