09-22-2025 03:10 PM
I'm unable to make outgoing calls to the US from Canada, So I used my points to buy the "300 International Long Distance Minutes" add on. It shows that I've used my points and that I've purchased this, but I still can't make outgoing calls to the US from Canada.
How can I fix this?
Thanks,
10-07-2025 10:09 AM
to PM , they have different LD add-on for different countries. US, UK and other countries have their own addon. Actually, it is to your advantage that US is by itself as the US Long Distance addon is cheaper per minute
10-07-2025 09:58 AM
Do you not consider the United Stated (a different country) to be international? Why is it called international minutes, if you can't make international calls?
09-22-2025 03:53 PM
09-22-2025 03:12 PM
if you want to call US, you need to buy the US specific addon, not the International one
if you have not used the International addon at all, PM support agent can help to change it or give you back the credit for you to buy the correct one
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
