Texting
Duffy69
I've recently moved to Public from Virgin.  I purchased a new Sim card and have moved my contacts over.  I am however unable to send or receive texts from most of them.  Any thoughts?  Took it to a kiosk but they were unable to assist and think it may be a faulty sim card.
Duffy69
Silly question I'm sure but how do I clear text app cache?
Duffy69
Good idea, I will try that tonight.
HI @Duffy69
iPhone or Android?
Start with Reset All networks
if iPhone, update the Carrier profile, disable iMessage, reboot and enable it back.  And if Android, clear text app cache
@Duffy69  Can you test the SIM card Ina mother phone to try ? Also try resetting network settings see if that helps . If same you can send support a message to investigate
send a  private message   To CS_Agents
