yesterday
I've been with public Mobile for a long time now. I'm suddenly have continuous network connection issues. Very bad reception and roaming where I didn't use to, with it on or off. I even swapped back to my old phone that used the same sim and having similar issues, pictures won't send over text. I have recently changed to the 5G roaming plan but it was like this before. I'm on Pender Island BC. My girlfriend has public too with no issues. Would replacing the sim card help. I don't know what else to do. Ready to move on to Rogers.
3 hours ago
@Rdub Unlikely a SIM issue, more likely related to the shutdown of 3G network. Where I live 3G is still much better than 4/5G; not looking forward to shuttering our local 3G tower. 😵💫
3 hours ago
You can also try a network reset of your phone.
Force your phone to the LTE network (instead of 5G network).
yesterday
@Rdub Can you try your SIM card in your GF phone and test and while at it try her sim in your phone and test . This way you can rule out if it’s a sim/ account issue or device issue
