03-21-2022 03:53 PM
I have tried more than 30 times to register, change password, remember security question, put in a new password, renew my account that has been cancelled because visa card is expired and need to update new information.
This is beyond maddness. FYI I have 3 University degrees with over 30 years of teaching in. I pity others who try to navigate this system without really getting anything accomplished.
System sucks
Rodney
03-21-2022 06:34 PM
@rodneyvokey1234 wrote:This is beyond maddness. FYI I have 3 University degrees with over 30 years of teaching in.
OK, but spelling is not your strong feature. Just joking, no offence. 😁
You can have 2 Ph.D. and you would still suffer this system. For some it works flawlessly, some are pulling their hair and cutting wrists.
Unfortunately system is far from perfect but that is what you get for low payment.
You should not try 30 times to do anything with the PM system. After 2-3 tries you should come here and ask for help. Now, probably your emails, account, whatever are so locked that you definitely need agents assistance.
Send them a note right away and calmly navigate PM registration. It is not worth to lose sleep over it.
03-21-2022 04:03 PM
@rodneyvokey1234 so you have not created a MyAccount/Self Serve before, then you must have activated in-store or by a 3rd party?
Are you trying to register using this link: https://selfserve.publicmobile.ca/self-registration/
Or, an account was set up before, and you are within 90 days of being an Active customer, then you are trying to use the Forgot your password here: https://selfserve.publicmobile.ca/forgot-password/
If you had too many failed attempts to log in you will get locked out, but just temporarily. Try again in 15+ minutes. When you do clear your cache/cookies, or open a tab in incognito mode.
If still issues, submit a ticket with CSA (by methods provided by @hTideGnow )
Then you can go to the PAYMENT tab and see the bottom, left corner to change/update your payment information:
03-21-2022 03:55 PM - edited 03-21-2022 03:55 PM
@rodneyvokey1234 best way to reset your password now is to contact PM CS Agent:
Click on the Bubble or directly at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
If you have problems submitting a ticket, you can also send a private message to the moderators (but this can take longer):
03-21-2022 03:55 PM
Get payment vouchers at local retail outlet, like 711, then add them to you account by dialing 611.
Then deal with cc issue later.
