Refund
Cruz201310
I would like a refund for lost service while traveling to Montreal on October 11th.  We lost four hours.
Chalupa_Batman
Hello @Cruz201310
Not sure exactly what you lost. Public Mobile is a prepaid service and usually there are no refunds. If there are technical issues then you must create a ticket to a CS Agent for help.
To submit a ticket with CS Agent using this Chatbot link
Type Customer Service and follow the prompts. If you are having any issues, here is a direct link by sending a private message
HI @Cruz201310
what you meant by you lost 4 hours?  you had 4 hours without service?
PM is a prepaid carrier and usually do not provide refund.  Also, for most carriers, they usually won't do much even with a 4 hours outage.
you can of course try to ask agent , but I doubt they will do much.   But if you want to go ahead and check with support agent, please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
hairbag1
@Cruz201310
PM will be very unlikely to provide a refund in your case. You may have been in an area of weak or non-existant service....not a PM issue.
