Refund
10-31-2023
07:52 PM
11-01-2023
01:25 AM
computergeek541
Hi, I just bought a plan that I don’t wish to activate. How can I cancel it and get a full refund?
Payment
10-31-2023 08:00 PM - edited 10-31-2023 08:02 PM
@Aym If you didn’t activate the sim then I do t think you will be charged , check your credit card is the plan charge just pending or had it posted ? If pending and you haven’t activated it shouldn’t post is my understanding . But you can confirm with support to be sure
send a private message To CS_Agents click
VVVVV Link below VVVVV
10-31-2023 07:57 PM
PM does not provide refunds if you do not like service.
10-31-2023 07:55 PM - edited 10-31-2023 07:56 PM
you can’t – as a prepaid provider, they don’t do refunds.
You can try your luck, but don’t expect them to comply and try to be as polite and reasonable as possible for any chance of success.
To contact a Customer Support Agent, send a private message to the Customer Support Agents by clicking here
You’ll need to be logged into your Community account for the link to work.
10-31-2023 07:55 PM
@Aym PM is a prepaid provider and do not provide refund. Maybe what made you change your mind to want to leave? let us know if any issue and maybe we can help
If you decide to leave PM, make sure your login My Account and disable Autopay (Subscibed) from Payment page so PM won't charge you in next renewal
10-31-2023 07:55 PM
you prolly won't get a refund. May as well use the plan for the next 30 days anyhow...maybe you'll stay.
