04-16-2025 06:26 PM
Seems like I ordered a eSIM card that I can not use how do I cancel my order and start my order all over again
Peter
04-16-2025 06:39 PM
first things first...what make and model is the phone your planning on using the esim in ?
04-16-2025 06:35 PM
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
But maybe check if you can enable the esim and make it works
first, do you see the esim on the phone's sim manager or Settings->Cellular? enable it or toggle on turn on this line
also, remove old sim card or disable old esim from your previous provider. Then Reboot phone first, and and click Reset network settings
04-16-2025 06:33 PM - edited 04-16-2025 06:33 PM
@37893 wrote:Seems like I ordered a eSIM card that I can not use how do I cancel my order and start my order all over again
Peter
Hey Peter,
Don't worry, you can reach out to a CS Agent and order a physical SIM card.
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket.
However, if you want one faster, here's how. You just need to reach out to a CS Agent to change the SIM card number.
To get a new SIM card the fastest routes are these.
https://www.publicmobile.ca/en/bc/pick-up-SIM - Find a local store in your area.
Amazon - Here you can get it cheaper and maybe a few days wait $4.99
