04-12-2022 11:31 AM
Hi there,
I want to refer my daughter to public mobile. I wonder if she should make her own account or I can use my account for 2 Sim cards?
And I saw the new offer for $25 plan with much more data than that I am using. Is there any way to switch the data of 2,5gb from her plan to mine? She doesn’t need that much data.
Thank you!
My Account
Plans
04-13-2022 11:01 AM
04-13-2022 11:00 AM
Thank you 🙂
04-12-2022 11:57 AM
Unfortunately you cannot switch but at least she will get her 10 dollar bonus and you will get your $1 a month once she uses your referral code.
04-12-2022 11:37 AM
HI @Kim13 No, you cannot have 2 sim cards registered on a single My Account. There is no family account here.
You cannot switch the accounts to get the 2 GB either. Some people will port out the number and port back in as a new activation to get the promotion. But this promotion is only for 12 months, might not worth the effort.
04-12-2022 11:36 AM
Make sure she uses your referral code which can be found below on your self serve landing page:
04-12-2022 11:34 AM
There's no family plan here. She will need to make her own account. There is no way to move these promos from one account to another.
04-12-2022 11:34 AM
There is no way to switch the data between accounts.
04-12-2022 11:33 AM
@Kim13 PM is one account for one phone line. So, your daughter will need to activate a new line with her email address. When she activates, make sure she enter your referral code, on page 4 of the activation portal.
Also, the promo is for new activation only and not existing 😞
