04-07-2025 10:10 PM
I have stopped receiving incoming calls from today ( possibly even before today)
I can call other number, my subscription is active but when someone calls me, they are routed to voicemail.
I was informed about it today by a friend and that is when I got to know about it
Anyone else facing same issue. I have restarted my iphone 2 times but the issue still exists.
04-08-2025 07:50 AM
@Dave_PM Make sure you don't accidentally have do not disturb enabled, or airplane mode. Sometimes with iPhones the left side button gets accidentally switched to "silent" also.
04-08-2025 12:45 AM
Does text and data work?
Might worth trying a network reset of your phone. Note: this will erase any saved Wifi passwords.
04-07-2025 10:38 PM
@Dave_PM which iPhone do you have? It could be the results of lack of VoLTE on your phone.
https://www.publicmobile.ca/en/get-help/articles/850-turndown
04-07-2025 10:38 PM
You might want to double check to see if you blocked your friend’s number or Silenced Unknown Caller if they are not in your Contact list.
Go to Settings>Phone>Blocked Contact and Silence Unknown Caller.
