12-05-2019 02:10 AM - edited 01-05-2022 09:56 AM
I referred s friend buy I did NOT get the $20 bonus. Can someone help me please?
12-14-2019 10:07 PM
Actually it takes couple of days to show up in your account.
12-08-2019 07:41 AM
Thank you
12-05-2019 10:58 PM
threads merged
12-05-2019 01:30 PM
@cros1378 wrote:I referred s friend buy I did NOT get the $20 bonus. Can someone help me please?
Did you friend use the correct referral code. There can be confusion about some of the numbers and digits, for instance, 0/O? Did your friend get the $10 referral credit?
Wait upto 72 hours and if you don't see it by then, get the friend to submit a ticket, with your referral code doubling checking all digits, to moderators via SIMon here: https://publicmobile.ca.ada.support/chat/
Type in 'rep', select 'contact us', then 'submit ticket' and follow the rest of the prompts.
12-05-2019 01:22 PM
You should get it if the person you referred to put your number in when he/she was setting up their account. Also sometimes it takes a while before the $20 get rewarded.
12-05-2019 09:52 AM
@cros1378 I marked the 1st post to suggest this as the solution. That is our preferred approach.
12-05-2019 09:02 AM
HI and THANK YOU.
I MUST HAVE MUST HAVE MISSED THE 72 HR PART
Thanks again, I will watch for it
12-05-2019 07:40 AM - edited 12-05-2019 07:53 AM
Did your friend activate their account ? According to terms The extra one-time $20 credit will be applied to your Self-Serve account within 72 hours of your friend’s activation. If they have then submit a ticket to a moderator by clicking on the question mark on the bottom right.
12-05-2019 06:29 AM
@Tom19 You can create a service ticket via Simon (?)At the bottom right of your screen
to message the moderators to have it applied to your account. Ask to speak to a human then fill out the form to the best you can and submit. Keep an eye on your private message box at the top right corner of your screen for a little number to pop up indicating a message. It's minimum 8 hrs for a response right now...expect a 24 to 48 hrs wait time currently.
12-05-2019 04:47 AM
I am also in the same situation. I got a text from PM about my referral and got the $1 in my account but not the promotional one time credit of $20. It is already past 72 hours.
12-05-2019 02:13 AM
12-05-2019 02:11 AM
