referred a friend
RW62
I referred a friend and he forgot to enter my code. Can this be corrected?
2 REPLIES 2
eddieO
@RW62, yes but your friend will need to contact a support agent as they will have access to make account changes. After contacting them, your friend should see the $10 credit within 72hrs and you will earn 1 point for each month that they stay on.
To open a ticket through the Chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
hi @RW62
yes, support can help.  Ask him to open a ticket with Support agent.  Support will apply it and he will get the $10 credit back and you will get the ongoing 1 point reward
submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can submit  ticket by direct message:
