Refer A Friend
SvenRicky
 "Combined Rewards amount cannot exceed the value of your rate plan."
Does this mean that I can collect rewards if the referral chooses a plan that is more expensive than mine?
1 ACCEPTED SOLUTION
Accepted Solutions
JK8
In actual fact you can receive up to $110 in referrals. Anything left over after your plan renewal will be added to your Available Funds.
Edit:
You can exceed your plan cost.
Each cycle you can receive up to:
$110 in friend referrals
$2 autopay
Up to $15 in community rewards
Up to $5 in loyalty
16 REPLIES 16
JK8
Edit:
$2 autopay
Up to $5 in loyalty
0PX9O4
@SvenRicky
No, it just means that you cannot get $16 in monthly rewards if you are on a $15 plan, for instance.
JK8
@0PX9O4 wrote:
@SvenRicky
Yes, you can exceed your plan cost. Anything extra is added to your Available Funds for future use.
0PX9O4
@JK8
If even if you have experienced otherwise in the past, the rewards terms are quite clear in this regard, so let's be clear about what they specify:
"You can earn up to your current plan value in Rewards, reducing it to $0. Once you reach the value of your plan, you will not be able to accumulate any further Rewards in that plan period, and you will not be able to save Rewards and apply them to future months."
From https://www.publicmobile.ca/en/on/get-help/articles/reward-rules
JK8
@0PX9O4
That statement has never been enforced for anyone.
0PX9O4
I'm not disagreeing with you. Rather, I'm reminding ourselves that PM is not obligated to provide new rewards in any month over and above the monthly payment amount.
JK8
Yes, definitely agree with you there. They can pull the plug on anything at anytime, although it is in their best interest for customers to refer as many people as they can.
technically $20.. for Oracles  🙂
True.. except there would be consequences.. i guess it will be a big Community protest if the rule suddenly changed.. LoL
