12-03-2022
05:29 PM
12-03-2022
06:14 PM
computergeek541
12-04-2022 03:40 PM
Yes I want to transfer my Koodo number to PM. You suggested I just go here?? Is here on my Koodo account?
Thanks
Blub
12-03-2022 07:37 PM
I did the port number once thePM account was set up from a prepaid Telus number worked within 1 hour after clicking yea
12-03-2022 06:30 PM
@Blub yes, it can easily be done if your Koodo account is still active. and is it Koodo postpaid account or Koodo prepaid?
if postpaid, you can go to My Account and click Change phone number.
but if Prepaid account, you will have to open ticket with PM support and have them to help
12-03-2022 06:26 PM
I want to retain my number from Koodo ..port it to Public Mobile.
12-03-2022 06:19 PM
Yes
12-03-2022 06:16 PM
Did you switch to PM and want to transfer number from Koodo?
Just go here
12-03-2022 05:34 PM - edited 12-03-2022 05:36 PM
If you're trying to Port your number from Koodo post paid, and you have already activated a SIM card here, log in to your self serve and go under the change number.
There, you'll be given the option to select a new number or Port your number from another provider. Enter your Koodo account information there, put your Koodo SIM back in your phone, and wait for the port authorization text. Reply "yes", then put your Public Mobile SIM card back in and reboot device.
If porting from Koodo Prepaid, needs customer support.
12-03-2022 05:32 PM - edited 12-03-2022 05:32 PM
Ummmmmm, what do you mean by recover phone number? Do you mean you want to port over from Koodo here? Or is this that you lost your number thats from koodo and you want it back? Please more details @Blub
12-03-2022 05:32 PM
More information please. Are you a current PM customer trying to port a number over from Koodo? Are you post paid or pre-paid with Koodo?
