My phone # is not working after canceling koodo
DonnaBrock
@DonnaBrock
Did you reply to the text from Koodo confirming with YES you are porting over to PM with the old active SIM in your phone?
Also, you need your Koodo account must be active to port your number over to PM. If you cancelled your Koodo account before porting then it will not work.
Since PM and Koodo are under the Telus umbrella. They might be able to retrieve your Koodo number so contact a CS_Agent and see if they can help. There is a good chance they might receive it.
Neil11
You will need to contact customer service agent to fix your issue. Either via the following link:
If you are having a difficult time, then you can private message CSA:
Send a private message to CSA through the following link :
hi @DonnaBrock
are you trying to move your Koodo number into PM?  Account needs to be active to have the number ported
you are lucky it was from Koodo, as Koodo and PM both owneed by Telus, maybe the porting team can do something
  I have sent you the porting support team number.  Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call
