03-13-2024
11:59 AM
03-24-2024
10:52 PM
Dunkman
I have been able to get landline or regular phonecalls from people, but if it is a private number, I dont recieve it. It would go to voicemail.
How do I fix this?
03-13-2024 01:29 PM
Was unable to find the settings even after some research, was never like this with my previous provider, Freedom Mobile, but everything seems good now. Thank you
03-13-2024 01:29 PM
hi @Incogka yes, Android has it too
but you found it.. I guess all good
03-13-2024 01:27 PM
Android, wasnt able to find it after even some research until now. Thank you
03-13-2024 01:26 PM
Wadnt able to find it on my settings until now... thank you
03-13-2024 12:13 PM
Hi @Incogka
If you have an android phone, go into phone, settings and check this. If it's colored or orange it's will block unknown callers. Move the slider to the other side to be grey like mine and you should be receiving them.
03-13-2024 12:05 PM
hi @Incogka iPhone or Android? Check if you have "Silent unknown caller"
03-13-2024 12:03 PM
@Incogka Do you have unknown callers blocked in your phone settings
03-13-2024 12:02 PM
Most likely you have enabled 'reject unknown caller' in your phone.
So, if phone number is not visible phone will reject call.
