Call history
Chau263
How can i see call history for a particular number?
hi @Chau263 if within 90 days, login My Account and check usage history
if you only see 60 days of usage using browser, you might need to use the app to find the full 90 days usage
TheSterlinger
If you sign onto your account you can look for the number and see your call history there. You can also check the logs on your phone by going into your phones call log. Look for the number your speaking of and if you haven’t deleted the call logs recently then you should see the number and information for about it.
Hollister
@Chau263
If you log into self service there is a Usage History link on the Overview tab.
