12-22-2024
02:41 PM
12-22-2024
09:09 PM
Dunkman
12-22-2024 09:08 PM
12-22-2024 04:21 PM
It was Roger’s number originally. Roger’s said it is now owned by PM, so PM has to reactivate it.
12-22-2024 03:42 PM
@Brakus In that case the number will go back to the carrier it originated from so if that was public mobile check with support , if it was another carrier you will need to check with them to try and get number back
12-22-2024 02:54 PM
I lost the number 2 days ago. I transferred a second number to my account not realizing I could only have 1. Now the second number I transferred in pushed out the original.
12-22-2024 02:50 PM
hi @Brakus how long you lost the number?? was your account suspended for over 90 days? if you call 1-855-4PUBLIC and enter that phone number , what the system says?
or you can check with support , you can submit by direct message:
