Reaching out to the Porting Team
caoxying
Hi there,
I am curious to know what are the service hours for the Porting Team. I need to follow up with them in order to process with my inquiry. Thank you for your time.
HALIMACS
Do you have their contact number, @caoxying ?
If not, i'll send it to you - check your private messages upper right on envelope icon.
HI @caoxying
porting team hours: 8am – 10pm ET
@caoxying @When you do port a number always keep your old SIM card in your phone until your old carrier sends a confirmation text to transfer @ that point you simply reply YES and will have 90 mins to do so
@caoxying @You can port your number yourself in self serve , but if you need to contacts a agent
To Contact CSA-agent; there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
