03-01-2022
11:43 PM
03-02-2022
12:23 AM
computergeek541
Thanks was trying to create an account before sim card gets here.......Regards.......Back to PM......Irishman4
Joining Public
03-02-2022 12:36 AM
You will need the 19 digit SIM number to create an account but you found that out. 🤔
03-02-2022 12:22 AM - edited 03-02-2022 12:25 AM
@irishman4 wrote:Hello......was a customer .......couldn't remember if i should create a self serve account before sim card gets here ..found out minutes ago on the web.......answer is NO ...sim has to be in and activated ....well sim will be here in a couple of days.....thanks for your help................Glad to be back........Regards......Irishman4
You won't be able to create a Self Serve account until service has been activated, nor do you need to. The only time that you need to perform this step seperately would be if/after you activated your service at a store. For activations done online/at home/at your offce etc., the Self Serve account gets created automatically during the activation process.
03-01-2022 11:54 PM
03-01-2022 11:48 PM
@irishman4 wrote:Thanks was trying to create an account before sim card gets here.......Regards.......Back to PM......Irishman4
@irishman4 you are not PM customer yet? you will need your SIM card, activate and will create the account together.
