Re 3g plan
09-29-2022 05:10 PM
Hi I need to upgrade the plan to a 4g added 25 for A 3G PLAN . CAN ADD MORE MINS FOR 4G PLAN
Plans
09-30-2022 01:00 AM
And if you mean that you have already added $25 for an upcoming renewal (that hasn’t happened yet) then YES you CAN go in and add more $ and schedule a change to any other plan (3G or 4G) to happen at your next renewal. But if you have just been renewed very recently you either wait for your next renewal to change or you can change right now (immediately) but you will lose the remaining days of your existing plan.
09-29-2022 08:39 PM
@Broadbandbruce If you've only just paid for the 3G plan contact the agents. See if they will change your plan immediately and give credit for the 3G plan.
To contact the agents, click on https://widget.telus.tiia.ai/publicmobile/publicmobile.html and enter your question in SIMon. Follow / invent the prompts until you reach the Contact Us button, click on it and a Submit Ticket button should appear. To confirm that your ticket has been submitted, check the SEND box in your private messages; click on the small envelope next to your avatar at the top right of your screen.
If you have problems submitting a ticket, you can also send a private message to the CSAs. Click: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
09-29-2022 06:00 PM
yes for outside of canada it's call out canada yes for international maybe the @Broadbandbruce need that
09-29-2022 05:58 PM
@Alexandf 2 posts in one thread that make no sense..😬
09-29-2022 05:58 PM
No worry @computergeek541 , we both interpret it the same way. Again, the original reply was very hard to understand.
09-29-2022 05:57 PM - edited 09-29-2022 05:58 PM
Do you mean to call outside of Canada? There was no references in the original question to international long distance calling.
09-29-2022 05:57 PM
"yes you can buy it add-ons for call out canada"
Hi @Alexandf First, your reply is very hard to understand
Let me make a guess, Call out Canada means long distance calling? The OP mentioned that somewhere??
09-29-2022 05:56 PM
i'm not saying Canada-wida ,, if you can read my post for call out canada. you have to reading and then you give your bad things,
09-29-2022 05:52 PM
09-29-2022 05:49 PM
09-29-2022 05:26 PM
Any plan above $15 has unlimited in/out minutes.
What exactly is your question?
09-29-2022 05:20 PM
@Broadbandbruce @You can’t renew then add the balance to upgrade.. plans are 30 days.. your stuck with what you paid for till next cycle. If that’s the case plan a change for your next renewal
09-29-2022 05:15 PM
@Broadbandbruce @And when did you renew your plan?
09-29-2022 05:12 PM - edited 09-29-2022 05:12 PM
What?? What plan are you on now? What plan are you trying to get to?
Adding - and what is your current balance?
