12-13-2021 10:43 AM - edited 01-04-2022 04:58 AM
Hi, I'm planning on adding 2GB of data for $20 to my current plan when I travel to the USA and I had a few questions regarding that.
1) How soon after the addition is the data activated?
2) How would I be able to track my data usage of the 2GB. I currently use my phone's data tracker but that's for my monthly plan.
3) How does the add-on work in relation to my current plan. For instance if I haven't used all 2GB within the ten day period would I have access to it when I come back to Canada?
4) When do the ten days start and end for the data add-on.
5) Does the add-on need to be activated in Canada or can I do it once I'm in the US?
12-13-2021 01:20 PM - edited 12-13-2021 02:00 PM
@BS2 : The line from that S dash user (Edit: but when you visit US and then Purchase it,,, not Purchase in Canada won't work,) is false. You most certainly can.
@foreveryeg: There's a peculiar waiting period of another day to re-buy the same one. But you can ask the CSA's.
12-13-2021 12:38 PM
Data plans start as soon as you buy them, for usage it should show up in the same place as your other usage info, it can be added in Canada or the us also if you need more then 10 days at the end of the 10 days buy another add on also once the 10 days start if it the USA package isn't used up it will be wiped from your account. Payment you can either have your account topped up in advance or you can just have a card on file for your billing!
12-13-2021 12:25 PM - edited 12-13-2021 01:12 PM
when you Purchase Add-Ons right away is will working
and go sign in to Self-Serve, to review your account, history data usage,
for more information about Managing Your Data Usage visit Here link to save your data...
and turn off background data, to save your data.
at public mobile 30 day Prepaid Service No fees extra charges,
For US Roaming 10 day packages
Unlimited U.S. Talk, Text and 250MB Data Bundle = $20
Unlimited U.S. Talk and Text Bundle = $15
Unlimited U.S. Talk Only = $8
Unlimited U.S. Text Only = $8
U.S. Data Only 10 day packages
250MB = $10
500MB = $15
1GB = $20
How To Purchase Add-Ons Using Your sign in to Self-Serve, Account
follow these steps:
after you Add-on you have to do Rebooting your phone
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
Overview Of Add-Ons visit Here link..
after 10 days for Add-ons expiry and waiting for 25 hr to re-Purchase or you need to Contact Customer Support Agent by CS_Agent, them can Add for you,
Here’s How To Contact Customer Support Agent by Submit a Ticket,
Good Luck....and Happy journey..
12-13-2021 11:55 AM
WIthin 24 hours ..reboot your phone after the purchase. ...
Just to be clear....the US add-on data is activated right away...no need to wait for 24 hours.
12-13-2021 11:47 AM
@BS2...the US Roaming data add-on is "live" as soon as you buy it. You have 240 hours in which to use it. That roaming data only works while you're in US.
Best is to buy it just before you go ...better yet, buy it when you get to US. In the past, I've used free wifi at Wallyworld to purchase the US Roaming options.
Enjoy your trip...mask up !
12-13-2021 11:42 AM
@BS2 wrote:Hi, I'm planning on adding 2GB of data for $20 to my current plan when I travel to the USA and I had a few questions regarding that.
1) How soon after the addition is the data activated? Immediately
Check your account Overview page/ Plan details
3) How does the add-on work in relation to my current plan. For instance if I haven't used all 2GB within the ten day period would I have access to it when I come back to Canada? You'll lose whatever is leftover after 10 days (240 hrs)
The countdown starts right after the purchase and ends 240 hrs later.
5) Does the add-on need to be activated in Canada or can I do it once I'm in the US? Either way, but it's better to do it as close to the moment you need to use it to avoid wasting time.
12-13-2021 11:11 AM
@BS2 : It's 1gb for $20 by the way.
1. Immediately
2. Check the overview page. Maybe 611 or 18554public would report the balance of roaming. You'd need your 4 digit PIN.
3. No, it's separate.
4. Immediately upon purchase. 240 hours later. You can buy the different named buckets in that time but not the same one. You would need to wait an additional 24 hours to re-buy the same or ask the CSA's.
5. Either. You just can't use it in Canada unless you're close to the border.
12-13-2021 10:51 AM - edited 12-13-2021 10:53 AM
In self serve 'my account' you ll be able to see how much plan is used up. there is a delay but it is there.
After 10 days expiration day it ll be gone, wait 24 hours before you buy another add-on.
10 days starts when your top up your account and purchase the add-on. End is 10 days after the purchase.
It is done over the self serve page of 'my account' so doesnt matter where you are, if you are in WiFi then you can do it.
Enjoy your trip.
