11-26-2024 02:48 PM
Just transferred today, I rebooted my phone several times. Speed is only a few mbps was getting very fast speed previously with videotron(I’m in Barrhaven). Does it take time to fully sync, what do I do if speed doesn’t increase, is there tech support. Can I get a refund if I leave?
sorry pretty basic questions
a month ago
@Waywen I just did a speed test in Kanata, 257Mbps down and 26Mbps up, FWIW.
11-26-2024 05:26 PM
@Waywen Mine is an iPhone 13 also and I'm in the Ottawa area on and off and never had speed problems there. I don't recall trying it in Barrhaven but since you went for a drive you should have got better than you currently are somewhere. I found it a bit lower around the Civic Hospital area one time, but up to and maybe slightly over 250Mbps in other spots. In some areas of Ottawa the phone shows 5G+. So something is not right, hopefully support can figure it out. You don't have the phone on low data mode by any chance?
11-26-2024 05:18 PM
I wondered about that, I would need to port out first. I might stick it out for the month then switch.
11-26-2024 05:17 PM
I actually went for a drive and see that the speed is fast in other areas so I just need to decide if I’m okay with terrible speed here.
Thanks for the response.
11-26-2024 05:01 PM
@Waywen I have iPhone 16 pro max on 5G plan and still only get 3G at times here check my screen shot and that’s in HRM with plenty of 5G towers but in the basement of house
11-26-2024 04:55 PM
hi @Waywen don't try to reverse it with your credit card if you need to port the number out. Your PM service will be suspended at once with the charge back and you would not be able to port it out
11-26-2024 04:47 PM
I will try to reverse charges with my CC company if convenient. Shouldn’t have these problems in the “city”.
11-26-2024 04:45 PM
iPhone 13th, should be fine I would think
11-26-2024 04:44 PM
Thanks all. I’ve reset the phone network setting still have a problem. One of our phones still on the old provider is getting 200mbps vs PM 2mbps.
I’m just wondering if I need to switch back or of this is an account set up problem.
I’ve submitted a ticket.
11-26-2024 03:15 PM
@Waywen I've always had good speeds in the Ottawa area, often up to the maximum Public Mobile advertises for my plan. If you want to contact customer support open a ticket at the chat icon bottom right of this page.
11-26-2024 03:15 PM - edited 11-26-2024 03:15 PM
hi @Chris_ @Waywen @what phone do you have?
did you try Reset Network Settings? or try your sim card in another phone?
if tried and same, ask support to geck further and reset your account
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
11-26-2024 03:12 PM
11-26-2024 03:10 PM
Does anyone here know, maybe Videotron uses a slightly different variant of technology than PM/Telus? I remember over 10 years ago there was a few different technologies being used among cellular carriers. Telus/Bell using CDMA, Rogers GSM?, and Wind Mobile came into the scene using different bands...
Maybe something like that going on here? Different bands for data, cellphone not having the best bands for PM?
11-26-2024 02:55 PM - edited 11-26-2024 03:00 PM
@Waywen Could just be network congestion , I get better speeds at different times of the day and in different areas at certain times . No ryhme or reason for it . Typically pre paid providers do not give refunds so if your. Not satisfied with the service i would say just port out couple days before your next renewal date to minimize money lost . But you can try and ask support for refund , just don’t think they will help thou
