11-24-2024 11:29 PM
Hi, 2 questions regarding public mobile points
1 Do you still get 5% public mobile points on the portion paid using vouchers?
2 Do you get 5% public mobile points on the portion when redeeming points?
thanks
11-25-2024 12:23 AM
@hairbag1 Incorrect. Points are not the same as cash; it's a discount you get on your bill. You only earn points on the amount you pay in cash (card or voucher).
You can see in September my points were 0.70 less because I redeemed 15 points for $15 off my bill.
11-25-2024 12:23 AM - edited 11-25-2024 12:25 AM
@hairbag1 wrote:to use points to reduce regular plan costs, customer has to manually redeem 15 points which will be shown as $15 in your account. Then, when regular plan renewal occurs, that $15 gets used and the balance owing gets paid from on file credit card. The points you get for that renewal are 5%...regardless if paid with all or portion in redeemed points.
There are no additional points awarded for points that are redeemed for account balance eventually used to pay for the plan. I actually mistakenly thought as you did before as well, but it's not the case. @DennyCrane has provided the correct answer.
11-25-2024 12:18 AM
11-25-2024 12:10 AM
1) Yes
2) No, as your bill is reduced by the points and you only earn points in the net spend
11-24-2024 11:49 PM
you get 5% on total plan costs...regardless of how it's funded.
