My questions marked as SPAM
11-25-2024 11:00 AM
Hi
Not sure why my question posts marked as spam ?
Had some questions before switch to PM, and looks like i can't go through even with simple questions on the plans.
Please advise.
Thanks.
Community
11-25-2024 11:34 AM
@alegator_23 You should still be able to use 2FA in all 3 countries , but you can also install authenticator app to help ensure it will work .
but if you port number to PM you can always port it back to Telus or to whom ever you want afterwards
11-25-2024 11:29 AM
and last 2 questions.
MFA from banks will work in 3 countries CAN/US/MEX (SMS sent from Canadian bank) ?
If i port number to PM, can it be ported to TELUS, or there are some restrictions due to being one group ?
Thanks
11-25-2024 11:28 AM
@alegator_23 You can confirm with support , but also it will say in the plan description if it has unlimited data like this example here
11-25-2024 11:27 AM
hi @alegator_23
no, all Roaming plans do not have unlimited reduced speed. So, if you used up the 50GB on that plan , data will stop working until renewal
11-25-2024 11:25 AM
Interesting, very confusing, as due to the fact that i couldn't post questions here i have asked the same question through the chat AI and got this answer:
When you exhaust all of your data on the CAN/US/MEX plan with 50GB, you will still have unlimited data available at a reduced speed of 512kbps until your subscription renews. So, your data will not completely stop, but the speed will be reduced.
Super confusing, any way to confirm 100 percent ?
11-25-2024 11:20 AM - edited 11-25-2024 11:23 AM
@alegator_23 No once the data bucket is used up it will just stop working , only 5G non roaming plans have the unlimited throttled data to 512kbps once reg plan data bucket is used up
until your next renewal or you would then need to buy data add on u til your next renewal in that case @alegator_23
11-25-2024 11:19 AM
Sometimes PM filters are to aggressive and if post has a link or numbers or dollar values it might consider it as spam.
Just do rewording and post again.
If Oracles consider your post as repetitive, abusive or repetitive they might remove it.
11-25-2024 11:19 AM
Second question
Wanted to confirm regarding data on plans CAN/US/MEX, in case you have exausted all of your data (50GB) will the data completely stop, or will it reduced to the lower speeds ?
Per offer details:
Data speeds reduced to a maximum of 512Kbps after your included high-speed data bucket is exhausted. Speed may vary with your device, Internet traffic, environmental conditions, applicable network management policies and other factors. Please refer to Public Mobile’s Network Traffic Management Policies here for further information.
Need to be sure, as don't want to be stuck without data , if I have used all 50GB.
11-25-2024 11:18 AM
hi @alegator_23
yes, you can use the service in US and Mex like you are in Canada
Also, you can call and recieve calls within these 3 countries, no additional charges
11-25-2024 11:17 AM
@alegator_23 Yes you can use in all 3 countries to call to and from using talk text and data no worries
11-25-2024 11:16 AM
will try to split the question,
CAN / US / MEX plan with Unlimited Canada, US and Mexico wide minutes and messaging plus unlimited international text and picture messaging
Does it mean that i can call / text /use data between and within these 3 countries (as didn't find anything about US->US, MEX-> MEX) ?
Please confirm ?
11-25-2024 11:15 AM
@Handy1, trying to reply, but after writing the questions and pressing on reply , the message can't be seen anymore.
11-25-2024 11:04 AM - edited 11-25-2024 11:04 AM
@alegator_23 could have been the system filter for whatever reason , but what’s your question about the public mobile plans ?
