10-09-2021 09:03 AM - edited 01-06-2022 03:44 AM
This is not a question but more of a statement, I purchased a phone which came from the US. Threw a SIM card in it and it works fine with public mobile. A lot of phones are completely unlocked now and if anybody was curious about purchasing a phone from the US, most do work with public mobile here in Canada with no issue. It used to be that phones had to be carrier specific.
10-20-2021 02:33 AM
The make and more specifically the model will indicate where the phone was manufactured for use. If its made for a domestic market other than the one the user intends to use it in it may not be compatible. So a Samsung S7 is normally a compatible phone but if it's made for the domestic market of Turkey then it may not be.
10-17-2021 11:02 PM
Carrier's phone protection. Makes sense to me.
10-09-2021 01:50 PM
@esjliv wrote:Still a good idea for people to check the Make and Models though when using with PM.
I do not see PM listing compatible phones; just frequency mentioned...
Will CSA will be able to help if somebody asks for particular model compatibility (if community does not know)?
10-09-2021 12:30 PM
Public Mobile uses the following frequency bands:
Good Luck
10-09-2021 10:34 AM
@Yummy wrote:
@softech wrote:yup .. it depends on the brands and carrier
Understood!
But if somebody is not able update phone's OS does not mean phone will stop working, correct.
It might not have latest 'security' updates or whatever fancy features newer OS brings but it continue to work as a phone.
I am stuck with Android v7.1.1 and no chances or way to go higher and I am OK with that.
Yup.. don't get it wrong.. your phone will still work. just might not be the latest Android version.. and again, not all unlock phones like that.. really depends.
10-09-2021 10:23 AM
Understood!
10-09-2021 10:17 AM - edited 10-09-2021 10:19 AM
@Yummy yup .. it depends on the brands and carrier
this was an example from someone unable to update an AT&T LG unlocked phone
How to update Android on AT&T unlocked phone - Community (publicmobile.ca)
10-09-2021 10:14 AM
My Motorola is from USA but I never had any OS update issues. Of course, updates have stopped due to phone's age but I believe as long as phone is unlocked and supports carrier's frequencies it should work and continue to work.
10-09-2021 09:37 AM
@Sdelo Yes, US unlocked phone generally works in Canada without issue.
But some phone sold by US carrier might not have OS update. OS updates on Android phones sold by carriers are very often pushed by carrier. While the phone might be unlocked, there is a chance that carrier still lock that part of the phone and updates still have be been obtained while the phone is on their network. It was legal and carrier has the right to do so. We have couple posts about the trouble for getting no more OS upgrade now.
10-09-2021 09:07 AM
@Sdelo wrote:This is not a question but more of a statement, I purchased a phone which came from the US. Threw a SIM card in it and it works fine with public mobile. A lot of phones are completely unlocked now and if anybody was curious about purchasing a phone from the US, most do work with public mobile here in Canada with no issue. It used to be that phones had to be carrier specific.
That's good. 🙂
Important features for usability are:
10-09-2021 09:05 AM
@Sdelo - thanks for the tip, that may be worth looking into! Happy Thanksgiving!
