11-07-2024 07:03 AM
Hi all,
How are you doing? I have a Galaxy S9 I bot in June of 2019. I am with public mobile and have been having problems with no network connection. I am on oxygen thrapy and need it to live, I need a phone that is relaible.
Is this my phone of the carrier?
Thank you
Service
11-07-2024 10:12 AM
Reset the Network Settings on your Samsung S9.
Go to Setting>General Management>Reset>Reset Network Settings. See if that helps.
11-07-2024 08:05 AM
You will need to contact customer service agent to fix your issue. Either via the following link:
If you are having a difficult time, then you can private message CSA:
Send a private message to CSA through the following link :
11-07-2024 07:14 AM
@CheekyKID Can you test the SIM card in another phone to try . Help narrow down if it’s your phone / setting or account issue
also can log into your account and confirm if it’s active or suspended
also check
Outage map in your area:
https://istheservicedowncanada.com/
If active and no outage and reboot device or reset network setting don’t work . And same result testing sim in different phone
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send direct private message to support .
