02-07-2021 05:37 PM - edited 01-05-2022 05:12 PM
Hello,
I just purchased an add on and it shows up in my account, but I’m still not able to use internet.
how long does this usually take? Do I get a text or something?
thanks
02-08-2021 07:23 PM - edited 02-08-2021 09:05 PM
@Olga1 wrote:Thanks for reply! Can you help me with that. I am no deals before with that and don’t understand how to do this steps correctly
@Olga1 Can you log into your account and see if your data add-on is listed under My Data & Add-ons (halfway down the page) first.
Have you used data before and have the correct APN settings on your phone?
Edit: Make sure you data is enabled on your phone too.
02-08-2021 07:20 PM
02-08-2021 07:18 PM - edited 02-08-2021 07:30 PM
@Olga1 wrote:I purchased 1 G data add on, my internet still doesn’t work. I restart my phone - doesn’t work
@Olga1 Did you first add funds and then go back to purchase the add-on as it's a two step process. Also did you purchase the correct add-on $15/1GB? You can try rebooting your phone if you see the add-on in your overview page of your account.
02-08-2021 07:12 PM
02-07-2021 05:48 PM
Lol that worked thanks a lot, much appreciated
02-07-2021 05:45 PM
It might be worth it to remove the SIM card and put it back in again.
02-07-2021 05:45 PM
@goatku12...
make sure you didn't get the 10 Day US Roaming data add-on. It only works whilst in US.
Please confirm and let us know.
02-07-2021 05:45 PM
02-07-2021 05:43 PM
I got a 1G add on, and it says I have it in my account as well
02-07-2021 05:41 PM
Except it doesn’t
02-07-2021 05:41 PM
@goatku12 wrote:Hello,
thanks
It should work right away assuming you got the correct add-on. How much did yours cost ?
02-07-2021 05:38 PM
![](/skins/images/02B49C0B2FC614613D221373CF8AAEF5/responsive_peak/images/icon_anonymous_message.png)
