04-09-2022 01:41 PM
Hi, I switched a few days ago to Public from Roger's. I haven't received any contact from Roger's to authorize a port transfer so I can keep my old number. So I was hoping someone could help me get in touch with Public so they can send a port request. Cause the self serve doesn't work either.
03-20-2023 08:54 AM
A critical part to porting is to receive a text from your old provider and you have to reply YES within 90 mins. If you are not receiving calls and text on your PM sim card, and only outgoing calls, wok then you might have missed the step and hence porting was not completed
There is a number to call to talk to live support, they can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
03-20-2023 08:53 AM
I change my carrier to public mobile since the 11th cannot receive call but the port transfer didn’t go through how do I get customer support to request another port transfer
04-13-2022 03:53 PM
HI @ibragg You have to call Bell and they will arrange the transfer text again
04-13-2022 03:09 PM
What do I do if I accidently deleted the transfer text. I have active number with Bell that I want to port to.
04-09-2022 02:10 PM
Well it wasn't working before, but now I got my number ported over thanks to the number dabr gave me. So it is fixed now 😅
04-09-2022 01:56 PM
In your last sentence you said self serve doesn't work?
Do you mean going through the Change Number option to port your number over; or do you mean you cannot access your self serve account?
04-09-2022 01:53 PM
Thank you so much 🙂 your the best!!!
04-09-2022 01:50 PM
@lukereimer1 Your account with Rogers needs to be active in order for the number transfer to complete. You also need to keep the Rogers SIM in your phone to respond to the transfer text with a YES.
If your account is still active, then phone the Telus porting number which I'll send via private message (check your message box top right)
