01-30-2025
12:17 AM
01-30-2025
11:23 AM
computergeek541
Once the Public Mobile SIM card is activated please get back to us so we can resubmit the port request. How will I know when this has happened?
01-30-2025 01:37 PM
hi @DougSalahub
can you confirm if you can make calls now and just not receive inbound calls?
01-30-2025 01:37 PM
are you saying esim is the problem or porting?
01-30-2025 01:35 PM
Trying to transfer my number.
01-30-2025 01:27 AM
Are you trying to switch from SIM to eSIM?
If you are, just contact a CS_Agent for help.
But make sure your phone Is eSIM compatible first.
What is the make and model of your phone?
01-30-2025 12:51 AM - edited 01-30-2025 12:53 AM
What is it that you are trying to do? You can tell a SIM is active when you have service with it installed in your phone. If your phone only allows one SIM at a time you would have to switch back and forth between them if you want to make sure they are both active before trying to port.
