10-27-2022 08:05 PM
Hello! I was wondering if anyone can explain to the advantage of subscribing to Public Points vs loyalty program.
Thank you,
Rachid
03-02-2023 08:51 AM
I was wondering the same thing? It looks like points are better when you see the bonus for subscribing and the points offered based on # of months with public mobile. In what way is not as beneficial?
10-27-2022 10:26 PM
Thank you for sharing.
10-27-2022 10:26 PM
Thank you for answering and for your advice.
10-27-2022 08:19 PM
There are certain cases, mostly where you are spending more money, that the points system is beneficial, but generally there are no advantages to it. For the majority it is beneficial to stay with the old rewards system.
10-27-2022 08:09 PM
If you're a newer customer after January 2022, you have no option other than Points program.
If you currently have the old Rewards program... just don't opt out in favour of Points. Rewards are superior to Points.
