10-18-2022 01:24 PM
Hi there,
My wife and I are using the same $15 plan with Public Mobile. When calling each other, will our plan use our outgoing phone call minutes? When both parties are Public Mobile customers do they get unlimited outgoing calls without using there minutes? Thank you.
10-18-2022 01:53 PM
Thank you!!
10-18-2022 01:45 PM
No. You can supplement your outgoing minutes with the $5/500 min add on. It's a one time purchase that does not expire rather it rolls over every 30 days until completely consumed.
You can also download the fongo or textnow app and choose a Canadian phone number. These voip providers are free to use on wifi or they work on mobile data (0.5mb=1min). You can now call each other without using outgoing minutes. They are handy to use to call your voicemail so you don't use outgoing minutes checking voicemail either.
10-18-2022 01:34 PM
Hi @Southside sorry no "discount" for calling PM customers. When you call each other, one of you will got charged for outbound calls
10-18-2022 01:33 PM
Nope...any calls you make while on the $15 plan will count towards your 100 minutes.
You'd need the $25 plan for both to call each other without using up limited minutes.
10-18-2022 01:31 PM - edited 10-18-2022 01:34 PM
@Southside hi the 15 dollar plan has 100 outgoing minutes so yes if you call your wife you will use your minutes, she will not ,if she calls you her minutes will be used not yours
