3 hours ago
Hello, I'm going to be travelling to the US in a couple days and was wondering if the US roaming add on of Unlimited U.S. Talk and Text Bundle for 15 days will let me make phone calls to Canada as well or will it only work for US numbers? Thanks for the help!
3 hours ago
I will do that for sure if needed! Thanks 🙂
3 hours ago
Sounds great, thank you so much for your help! 🙂
3 hours ago
@Mollyy yes, as long as your iPhone is running iOS 16 & above you should be fine on all 3 U.S. partner carriers (T-Mobile, AT&T and Verizon). If you find you are having issues with one try manually connecting to one of the others
3 hours ago
yes, iPhone 11 would work beautifully with VoLTE
Buy the bundle closer to when the trip starts, as the 15 days count start right a way
and when you are in US, make sure you turn on Mobile data roaming. Make sure your phone connects to T-Mobile or AT&T , better to use 4G as 5G might not be as stable
3 hours ago
Thank you for the prompt support!! I'm using an iphone 11 so will that work?
3 hours ago
yes, the bundle allows you to call back Canada and call US as well. Of course, you can receive calls too
but what phone you are using? easier if you have a VoLTE whitelisted phone by PM. If yours not on the list, then you will need to use T-Mobile's 2G network, which might not work well
