Incompatible data add-on
LisaS1
I used 25 reward points to get the Unlimited U.S. Talk, Text and 3GB Data Bundle (15 days) but when I go to my account, it says my Talk and Text is available but then it says Incompatible Data Add-ON so I don't think I have access to the data.  Why? If that is the case then I just wasted 15 reward points because I could have just used 10 points to get the US talk and text
8 REPLIES 8
LisaS1
So even though it showed on my account as incompatible, it still worked in the US.  Not sure why but glad it all worked out.
CSA_PM
Customer Support Agent
Hello @ LisaS1,
I sent you a private message. You can view and reply to it by accessing this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
LisaS1
It is an Iphone XR so I think it should be fine
@LisaS1
while you wait...what cellphone are you using for talk in usa ? It must be a phone that has VoLTE recognized by Public Mobile...not all are. Here's a out of date list...see if your cell is on that list...
https://www.publicmobile.ca/en/get-help/articles/volte
Without VoLTE, your calls in us will fail.
LisaS1
Thanks.  Hopefully I get a response soon.
@LisaS1
the screenshot does show the US roaming is incompatible.  I have helped to escalate this issue with PM support, they will reach out to you via private message.  Please check your community inbox for their reply
LisaS1
Leaving for the US in a few hours.  This is a screen shot of my account.  Not concerned about the bonus data from Christmas:
@LisaS1
The incompatible data is not referring to the  US roaming data, it is referring to the bonus data you received from Christmas before
Are you in US now? Make sure you turn on Mobile Roaming Data on the phone for US data to work.
If you still need PM support to check and confirm, please open ticket with PM support:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Log In", finally click "Click here to submit a ticket ↗
