yesterday
yesterday
I am chatting with an agent, I follow all the instructions..., nothing works.
yesterday
Hi, @HALIMACS thank you for your reply. The data and text work but I can't make and receive calls
yesterday
@will13am Thank you for your reply. It seems like the data and text work.
yesterday
@Ghyna , are you able to establish a mobile connection? Does data and text work?
yesterday - last edited yesterday
Does NOTHING work (calls, texting, and data?)
Try rebooting your device, resetting network connections and toggling airplane mode on and off.
Is your account active? Login to your self serve to check the account status. If not, perhaps your last payment didn't go through. Make a payment to restore services.
If all that is good, reach out to a customer support agent.
