Promotion Details
02-22-2024 04:54 PM
I have two questions on the following promotion
Question 1 - The last bullet point says earn $2/month in points value. I am not currently on the Public points system. Currently I received a $3/month credit and $2/month autopay credit. If I take this offer will it automatically move me over to Public Points?
Question 2 - Is the 50 GB/month or 50 GB/90 days
Thanks for your help in advace
Rewards
02-22-2024 05:16 PM
@UEL Yes no worries you will keep your old rewards . You have to voluntarily choose to switch to points rewards . The bullet point is for new activations since Jan 2022 that are in the new point system only . I have this plan too and kept my old rewards
02-22-2024 05:13 PM
Thanks. Just to clarify I could accept the new plan and my old rewards would not change? Which would mean the last bullet point in the offer would not apply to me as I could stay in the old system
02-22-2024 05:02 PM - edited 02-22-2024 05:03 PM
You won’t receive points if you are on the old Legacy Rewards so DON’T switch to the Points Reward. The old Legancy rewards is better plus you receive monthly credit rather than collecting points.
This plan is 50gb/month for $40:month or 150gb/90 days for $34/month but you need to pay the 90 days ($102) upfront.
02-22-2024 04:59 PM
@UEL You won't automatically be moved to public points and most people say you're better off staying on the old rewards system. You would have to deliberately make the change to points.
The plan is 150GB up front to last the 90 days and the payment is $102 up front ($34 x 3) also.
02-22-2024 04:57 PM
@UEL You will keep your old rewards they won’t change and in the 90 day plan you at the end of 90 days you will have 3x the rewards you get now
and for the data allotment it’s 50GB for 30 days but in the 90 day option you will pay $102 upfront with 150GB to use over 90 days
![](/skins/images/813D49D689E0D681E39391EAB60FD666/responsive_peak/images/icon_anonymous_message.png)
