03-20-2022 07:25 PM
03-28-2022 08:25 AM
Perhaps that is a possibility. My plan is done now so too late to check.
03-28-2022 08:21 AM
I have an iPhone. Roaming and sms are enabled. Actually, the texts I send seem to be delivered on time. It’s the texts I receive which seem to be held up.
03-28-2022 08:19 AM
I tried rebooting my phone. That seemed to reduce the wait time for my texts to arrive to one hour instead of 6. Too long still.
03-28-2022 08:17 AM
Yes, the add-on was purchased correctly, by first paying and then adding the plan.
03-20-2022 07:46 PM
I'd suspect someone was using iMessage instead of SMS.
Request that senders utilize SMS only when sending texts to you and not rely on web-based texting platforms.
03-20-2022 07:38 PM
@Meow Yes that's been the case always for receiving texts. US only.
03-20-2022 07:37 PM
Do you have an iPhone? Or are you using chat features (RCS)? Did you recieve the "texts" once you connected to wifi? Ensure you have roaming enabled. If you have an iPhone make sure you have SMS enabled. If you are an Android user turn your chat features off. Chat features require a US Roaming add on as does iMessage (or wifi) to be sent or recieved.
Incoming SMS does not require a US Roaming texting add on.....only if you want to send SMS is it required.
03-20-2022 07:36 PM
@dabr wrote:@Meow You don't need to purchase a roaming text add-on to receive incoming texts but, of course, OP won't be able to reply to those texts without purchasing roaming add-on with texting component.
Really?! You know that as a fact? I was not aware of that!!! Will that work in US only or world-wide?
03-20-2022 07:34 PM - edited 03-20-2022 07:35 PM
@heatecke Have to agree you shouldn't have to wait to use your roaming add-on. So were you able to send and receive them without issue after receiving the delayed texts?
It's a good idea to reboot your phone and also to manually select either AT&T or T-Mobile as one carrier may have better coverage where you are than the other.
03-20-2022 07:28 PM
Did he follow proper process of buying add-on?
Purchasing an add-on after logging in into your PM account is a two-step process. You need to load funds first and then purchase add on.
https://www.publicmobile.ca/en/bc/get-help/articles/purchase-add-ons-through-611
https://www.publicmobile.ca/en/bc/get-help/articles/purchase-add-ons-through-self-serve
