07-30-2021 08:10 PM - edited 01-06-2022 02:58 AM
I recently switched to a Galaxy S7 Edge. I put in my SIM card and it recognised it, but some stuff is working while other stuff isn't. I can send and receive texts and I can receive phone calls, but when I try to check my voice mail, it says that I'm out of minutes, even though I haven't used any. Data often doesn't work, and when it does, it only works for certain things, and it says on my phone that I've used more data than it shows on my Public Mobile account.
I changed APN settings as recommended here: https://www.publicmobile.ca/en/on/get-help/articles/set-up-data-on-an-android-phone but I'm still having problems. Has anyone had any similar problems? What is the solution?
07-30-2021 09:59 PM
I moved the proxy and changed the port
07-30-2021 09:50 PM
@LucasLucas : Which one...moving proxy or using the different one? Those MVNO's often have values in them but if it's working for you now then great.
APN type might want to have ,mms added and maybe ,supl and ,dun - no spaces.
07-30-2021 09:46 PM
This worked, thank you very much! The only options below were bearer (unspecified) and mobile virtual network operator type (none).
07-30-2021 09:41 PM - edited 07-30-2021 09:45 PM
@LucasLucas : Can you tell us any further fields at the end?
Another option is to try:
MMS Proxy = mmscproxy.mobility.ca
MMS port = 8799
Oh hold on...
Move that ip address down to Multimedia message Proxy and blank out Proxy and keep the rest (but I'd still like to know any further down fields)
And you only need to flip in/out of airplane mode to reset.
07-30-2021 09:36 PM
I added it and restarted my phone, but still only Gmail works
07-30-2021 09:33 PM
@Anonymous wrote:@LucasLucas : It would be easier to add the images here. Anyway...change the aliasredirect to add in front - http://
You might have a couple more fields at the end.
The APN type might need some work but let's see what you get with the http.
That particular field is for MMS. It should not affect data. Just having sp.mb.com correct should enable data. Even an empty APN type field could work, although it is best to include default,mms just in case there are multiple APNs available on the phone.
07-30-2021 09:31 PM
@LucasLucas wrote:Voicemail is now working, but I'm still having problems with data. I'll get notifications from apps, but when I try to actually load them, they won't work. The only app that seems to fully work with data is Gmail. Here are my settings: https://imgur.com/a/zezHyFn
Try selecting LTE/GSM/UMTS instead of Global.
07-30-2021 09:30 PM
07-30-2021 09:18 PM
Hi, everything works fine with wifi.
07-30-2021 09:16 PM
Glad you're making some progress... quick check - if you connect to your (home?) wifi, do your apps work okay? Just trying to narrow down the problem and eliminate some of what I hope to be obvious non-issues.
07-30-2021 09:14 PM
07-30-2021 08:28 PM - edited 07-30-2021 08:41 PM
>account.
maybe the phone was counting it on the monthly cycle and not 30 days
also, if the phone was used on another SIM card right before you change to PM SIM.. the phone data count would include data used on both SIM card.. (unless you are certain that you updated the cycle date to reflect the first day you switched to PM)
how much the difference we are talking about??
07-30-2021 08:15 PM
Can you call out to other numbers beside voice mail?
Maybe try dialing one of PM voice mail access numbers:
If that works, set your dealer to call that number to check your voice mail.
Maybe screenshot your APN settings. There might be one minor thing that needs to be changed.
Some basic troubleshooting advice:
reboot phone
network reset of phone
toggle airplane mode on, then off.
removed and re-insert your SIM card.
07-30-2021 08:12 PM
can you try it selecting the network to "3G ONLY"
for android visit HERE ,
if you still not working do one thing Make sure your phone is off before removing your SIM card,
and do rebooting your phone take your SIM card out and waiting for a 2 minute and put it back and turn on -This one is quick and simple.
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
or can you do try reseat the SIM card
1. power off your device
2. take out the SIM card,
3. wipe it clean SIM card,
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone means to turn off your phone and turn it back on again.
