06-14-2016 12:39 PM - edited 01-04-2022 12:55 PM
Updated July 20/17.
To view private messages that have been sent to you, locate the small envelope to the left of your avatar. Click it and your mail will be displayed.
Normally the feature "email subscriptions for private messages" is automatically activated. If you wish check, click on My Settings under your name, then in the Preferences tab you will see "Private Messenger". Email subscriptions for private messages can be toggled on/off.
If you want to reach the moderators now click this: message to moderators.
Otherwise to create a private message for someone, locate their name in a post, or anywhere you see it, and put your mouse pointer over their name. When this box appears click Send Message and compose your message.
11-24-2016 09:26 AM
11-24-2016 09:24 AM - edited 11-24-2016 09:26 AM
Hover over name (mine as a test)
Click on "send message"
It opens message screen
Click on tab for "sent messages"
It has to be there
11-24-2016 09:08 AM
11-23-2016 07:45 PM
@reh if you click on sent you will see your message history
11-23-2016 06:48 PM
11-19-2016 09:48 PM
@khenquach Follow the directions in this link:
If you are transferring a number, try your old SIM. If it works use it until it stops. Do Not cancel your old account.
Channel your patient persona. 🙏
11-19-2016 09:30 PM - edited 11-19-2016 09:32 PM
@khenquach You cannot activate the Sim card because you have already activated it. Even though the website said it failed, it actually did go through. Hopefully you just chose a new number and are porting an exisiting number (if applicable) later, otherwise the port during activation could have partially failed. Insert your public mobile sim into an unlocked phone and see if you have service, make sure you restart your phone. good luck!
11-19-2016 09:24 PM
Please help me to activate my sim card because when I activate it and it fails. Now it does not allow me to activate my sim card. invalid sim when i activate it.
11-15-2016 07:07 PM - edited 11-15-2016 07:07 PM
@richardini Please edit your post to remove all personal information; this forum is open to the public.
Send a private message to @Shazia_K with your phone number and the explanation you have here.
It will be several days before a moderator can respond but I am sure it will be adjusted.
11-15-2016 06:15 PM
Hello: In order to give public Mobile a try, I bought 10-day plan that expired yesterday, Nov 14th. Few days ago, I had logged in on my account and changed my plan to 90-day promotion. When I changed it, I clicked on the key for <Change on Renewal Day> but THAT DID NOT HAPPEN but rather renewed the first plan (10-day plan). So I logged into my account and changed myself to 90-day, and now I got it for 90 days. But, the problem is that I was charged for both plans, so besides the $120 for the 90 days, I have been charged $35 as well that would have been for the 10 days.
Can you please advise how can I have the $35 credited to me?
My phone number 613-709-1779
NOW, I AM ON THE RIGHT PLAN- 120-DAY
I just need to be credited the $35 of the old 10-day plan that I started with, and which was supposed to be switched automatically on the renewal day (yesterday Nov 14), but it did not so I had to do it myself.
Thanks,
10-05-2016 10:40 PM
Amazing. Straight and clear as water. Bonus with the Images:)
Tnx
06-14-2016 07:06 PM
@Luddite fantastic, and sorely needed!
@Shazia_K are you able to make this a sticky topic?
06-14-2016 06:53 PM
+1 Bravo
This is one of the least intuitive features on the boards
*hint hey Public I think I saw some Ideas to make it easier to notice... 🙂
06-14-2016 12:49 PM
@Luddite,
WoW, amazing post, you're awesome!!!! ![]()
Shazia
