Porting out
06-13-2022 10:28 AM
I am porting out my number ,I want you to manually port out and release my number
My Account
Rewards
Service
06-13-2022 11:43 AM - edited 06-13-2022 11:45 AM
whoops, sorry, didn't mean to post blank there...
@Deeksha are you being asked for a PIN to port into another provider? Best to use your Public Mobile Account Number when porting to another provider.
You really only need the PIN to verify your account or access information when calling 611 or your account remotely.
If you cannot log onto your account to find out your account number then follow steps to submit a ticket provided by @hTideGnow .
OR, you may have received an activation email when you activated with Public. In that case, see the To line of the email, it has your account number in it.
06-13-2022 11:24 AM
@Deeksha wrote:Can I get the pin num for my account
If you do not know your PIN you have to ask agent to change it for you. They cannot see it so they can only update it.
06-13-2022 10:51 AM - edited 06-13-2022 10:51 AM
HI @Deeksha For PIN, you can try to see if it was sent to you in any email from PM in the beginning.
if it is not there, you will have to open ticket with CS Agent and have them to reset it for you
To open ticket at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
- First type: "Forgot log in information"
- Then Click "Contact Us"
- Finally Click "Click here to submit a ticket"
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
06-13-2022 10:48 AM
06-13-2022 10:46 AM
Yeah, you need to go through the usual porting process and you will need your PM account in good standing and sim in the phone to get the porting text.
06-13-2022 10:46 AM
The account is active
06-13-2022 10:41 AM
Is your Public mobile account active? You need an active account to port out (except for Telus or Koodo). You will need to contact your new carrier to resend the port request. Keep your PM SIM card in your phone to receive confirmation text.
Here is some more information about porting process:
https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
06-13-2022 10:32 AM
They are initiating the req but I m not getting the message
06-13-2022 10:30 AM
I am not even getting a message ,they told me to contact public
06-13-2022 10:29 AM - edited 06-13-2022 10:31 AM
@Deeksha hi you must ask the service provider you are porting your number to so they can initiate request once you do that leave your public sim in your phone to receive port request respond yes to text
