06-13-2022 08:21 AM - edited 06-13-2022 08:29 AM
I have bought a voucher at shoppers drug mart on jun 12 2022 at 11:13pm. My pin was Once I put in my pin it said I was activated .. I tryed using my phone around 12:00 1230am and it said ur having a system up date.. I wake up to use my phone it’s says I’m not actived and that my pin is in valid !!!!! Not happy
06-13-2022 11:58 AM
What does 611 say? If it wants money then you're suspended and don't have enough balance. What plan are you on? If it says a renewal date and your balance then your account is active.
Just adding money doesn't do anything until you do something with it ie. renewal at your 30 days or buy add-ons. This is not pay as you go.
06-13-2022 10:17 AM
Can I speak to a freakin person here this is killing me
06-13-2022 10:16 AM
I can’t log in to my account… i don’t know why this is the worst experience I have had !!! Get this thing working !!!!
06-13-2022 09:35 AM
@Tylerbennet wrote:Why does it say that my service is suspended when I just put minutes on??? I have 30 dollors on it ??? What is going on
@Tylerbennet So, there are $30 in the Available Fund? is your plan $25 or $15 ? If so, it is an easy fix
You can do this to trigger the renewal manually:
06-13-2022 08:52 AM
@Tylerbennet wrote:It says I’m suspended why wtf
@Tylerbennet why don't you stop taking a hissy fit take a deep breath and listen to the advice given to you from @softech it is sound advice!!
06-13-2022 08:50 AM
06-13-2022 08:48 AM
06-13-2022 08:48 AM
This is bs I have 30 on my phone and I can’t make a phone call ????
06-13-2022 08:42 AM - edited 06-13-2022 08:43 AM
@Tylerbennet wrote:Some one better help me or I’ll be going to a different company 🤬🤬🤬🤬🤬
@Tylerbennet we are all customers like you. We are trying to help, that's why I suggest you to check My Account. That is the first thing you should check to see what is going on
If you want formal PM support help instead , you will need to open a ticket like what I said above. They will reply within an hour or two and you work with them by messaging with them
Yes, moving to a different company can be an option, but if you need your phone number to go with you, ONLY active account can be ported out . So, you still need to get your account active again before you can go away with your phone number, unless you decide to give up the number as well
Please first check My Account as I advised above first. At least understand what happened. Then you have a choice to just work with PM Support by opening ticket or provide us more details and we try to help 🙂
06-13-2022 08:37 AM
06-13-2022 08:36 AM
It wasn’t used.. it said it had the money on it when I typed in the pin.. ???
06-13-2022 08:33 AM
@Tylerbennet wrote:This is not cool get it working.. I have payed and this is a major inconvenience
@Tylerbennet You can try to reboot your phone once and see
If still not working, please check your My Account as I mentioned above. It might be just little glitch that we can try to help you to fix. It likely is the quickest way to get your service working again
If you like you can also open a ticket with PM Support at the same time, but it will be an hour or so turn around.
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
06-13-2022 08:32 AM
I don’t like typing all this it’s vary frustrating
06-13-2022 08:31 AM
06-13-2022 08:26 AM - edited 06-13-2022 08:27 AM
@Tylerbennet hi you will be even more unhappy if someone steals your voucher you are on a public forum anyone can see your info!! click on the down arrow in the little circle top right corner to edit your post
06-13-2022 08:24 AM
@Tylerbennet Please remove your PIN, this is an open forum and you don't want it posted here. Go back to your post, click the down arrow and then select Edit Message and remove the PIN
Can you login to My Account, does it show your account Active, Plan Expired or Suspended?
Is there any Available Fund in My Account? Maybe the voucher amount is sitting there and wasn't used for renewal yet
Can you also check the Transaction page ( https://selfserve.publicmobile.ca/Overview/payment/Payment-History/) and see if it shows the voucher was entered and if the amount was used
06-13-2022 08:24 AM
I have payed for service with a voucher and it’s not working
06-13-2022 08:23 AM
Yo I need help
