Phone Compatibility
remyhuggs
Is an ancient motorolla razor compatible with the network? The check phone compatibility tool doesnt work.
Also is there a way to buy pay as you go minutes for a sim card?
dust2dust
Does it have a sim? If not then it's the old CDMA. No one in Canada will run that phone.
@remyhuggs  - the compatibility tool, when working, is not fully updated all the time anyway.
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz (band 5), 1900 MHz (band 2) and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
Does any of these sites have your model?
https://www.kimovil.com/en/frequency-checker/CA
https://willmyphonework.net
https://www.frequencycheck.com/
  • 3G or WCDMA 2 (1900 MHz ) and 5 (850 MHz) bands  makes the phone compatible, which is needed for phone calls, and can also be used for text messaging and data.
  • LTE can be used for text messaging and data.  Data will work on the HSPA network.
@remyhuggs   Which Razor model?  If it is the old one, I think they are only 2G, aren't they?
(there is a reborn version that came out last year, but I assume you didn't mean that?)
Give us the exact model to confirm.  Of if you have the sim that fit the sim slot there, test it out  🙂
MrSpock
@remyhuggs hi what is the model number,and no there are no pay as you go here
