Porting my number
Mariaclean
Online support no help.Number never get ported.Ha can i get the process restarted.
8 REPLIES 8
Mariaclean
Thanks for the help rerstarted the process hope it will work
@Tashik  I'll private message you the number as we are not to post it here on the public forum.  Check your envelope icon top right in a few minutes, or select your avatar and then Messages if no envelope icon.
Tashik
I am also having porting problems with 3 different phone lines trying to port in.  What is number?
@Tashik   The phone number is for porting problems only
Tashik
A number to call public mobile?
HI @Mariaclean
so, you never got a text from your old carrier
Call the porting team and they can reinitiate the process.  I will send the number to your Community inbox.  Check and call porting team now
@Mariaclean
There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
hairbag1
@Mariaclean
use this link to message the Customer Support to restart port.
added...click the highlighted email icon on top right side of this page...I sent a number to you for port assistance.
