3 weeks ago - last edited 3 weeks ago
Good day,
I noticed there is a new recent requirement for credit cards.
Prior to May 2024, all you needed to enter is the CC number, expiry and 3-digit CCV.
Now, it's also requiring a postal code associated to the billing address.
I actually use prepaid credit cards, does this mean they won't work anymore? I've never set a postal code to a prepaid CC before.
thanks
@ turtleTurtle I tried many postal codes, none worked. Postal code has to be registered with the prepaid card, apparently.
3 weeks ago
Enter you postal code and see what happens??
3 weeks ago
@Raul_Davalo wrote:what type of prepaid car are you using, that can be registered with an address? Vanilla Visa / MasterCard?
thanks
I use all kinds. Usually the Joker Mastercard. I put a .... ummm... hehehe. I'll send this in private. Look up top right corner of page. 😎
thanks
3 weeks ago
Hey @Raul_Davalo
When you go into register your pre paid credit card, just add your postal code to it. Super easy to do. That's what I did.
3 weeks ago
HI @Raul_Davalo
for the postal code for prepaid credit card, you can just enter any valid one. Best to use the same one as your address
