05-29-2023 05:42 PM - edited 05-29-2023 06:15 PM
Hi, I've ported over from rogers on my iPhone 11, received the text from Rogers to start the transfer, replied Yes, however now the esim is stuck on "activating...". How do i resolve this problem?
EDIT: Update, the situation resolved itself after timing out and reactivating the eSIM again. Thanks all for helping out.
05-29-2023 06:25 PM
@Wynner Fingers crossed !
05-29-2023 06:24 PM
thanks @Wynner for confirming.
05-29-2023 06:21 PM
Thanks for the update, I had a referral that had the same issue, the port eventually went through too.
05-29-2023 05:52 PM
Resetting the network setting doesn't work unfortunately. But I've PM the CS, let see if they can help.
05-29-2023 05:51 PM
Thanks for the update, I've submitted a PM to the CS. Let see if this can be resolved.
05-29-2023 05:45 PM
hi @Wynner
there is problem with esim activation as one post said, he got thr reply from agent and asked to try again in 6 hours
but submit a ticket for yourself as well and check if same reply
05-29-2023 05:43 PM
