Ported but cannot receive calls or text
Blackcat0808
Ported from Rogers, everything works, but cannot receive calls or text.
Blackcat0808
My phone is showing on my pm account, data and making calls works fine. I am only having issues receiving calls and texting.
Blackcat0808
Hi, I did reply yes. I use my daughter's phone to call 1 844 number but I cannot receive text and when I gave her number it hangs up on me and tell me to use the online help.
Yummy
Well, it looks Nothing works since you cannot receive calls nor sms.
Confirm your phone number and account status after logging in to PM account.
hi @Blackcat0808
Did you get a text from Rogers to approve the port?, did you reply Yes within 90 mins?
It could be an incomplete port.  PM porting support team can help.  I have sent you the porting support team number.  Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call.
And in case the poring team cannot help and ask you to submit ticket (or you rather submit ticket anyway),  you can submit  ticket by direct message:
